It's always good to see you post Jack and I hope all is going well with you. Those machines tell me that you're still in business.
Maybe that's something to consider, but I have a pretty good size shop, 32'x44'. And we don't have much room on OUR property, so I rent space across the street.Jack.
I am fortunate to use a garage that is attached to my home as a shop. I have seen some shops created from used shipping containers. They are weather resistant and in the USA are quite affordable. If I didn't have the garage, I would more than likely try one or more of these units. Some are even insulated. Just add a door and a couple of windows and some power, and maybe a source for some heat.
Dan
Harry, always an honor to have you comment on one of my posts! Yes, I'm still in business and moving forward to a time when I do shop work exclusively and no more crazy customers with their Taj Mahal expectations. Or grungy disgusting work, or working outside in 0° (Fahrenheit) weather.....It's always good to see you post Jack and I hope all is going well with you. Those machines tell me that you're still in business.
Jack, you need to get this. I am really bad at spelling and this helps me from being so dumb. It's also free. :smile:No more editing posts? I have misspelled words and it drives me nuts!
I had the same problem in the garage, so laid in some NM (Romex) and hired an electrician to tap into the main box. Then I discovered the electrical outlets for the washer and dryer. Put in a 10 gauge short extension and plugged in both appliance and tool extensions. I never use both at the same time, and just drop the extensions near the tools where they'll be used. Simple, on breakers, cheap. With heavy insulation in walls and ceiling, it stays workable in there. I sometimes turn the gas fired dryer on to warm it up a bit. The steel roll-up door is now insulated with both foam and front and back layers of radiant bubble wrap. If I keep the door closed, heat sticks around pretty well. All that really keeps the heat down during desert summers as well.My shop is so small, I have to go into the basement to change my mind. With winter coming on, I've decided to frame in the metal garage door and put insulation in it, then cover it with OSB. I plan on adding shelving that will help the space problem. The only fly in the ointment is the electrical wiring stinks.
The best solution if you need more circuits is to have a small subpanel installed in the garage. It's easy to run plugs and lights from it plus you can have 220 that way for larger machines.My shop is so small, I have to go into the basement to change my mind. With winter coming on, I've decided to frame in the metal garage door and put insulation in it, then cover it with OSB. I plan on adding shelving that will help the space problem. The only fly in the ointment is the electrical wiring stinks.
Mike, same barn, more tools, less room! I now have 5 tablesaws, not counting 2 jobsite tablesaws and 2 tile saws. So for shop saws I have a 12" Grizzly cabinet saw, a 10" Jet cabinet saw, a 10" Craftsman hybrid saw, a 10" Ridgid TS3650, and now a very much disassembled Robland E300 3phase saw. I have a 20hp phase converter and I hope next spring to get out there and get all this stuff up and running. I also bought a Seco 24" belt sander, again 3 phase so I've never seen this run either. I got good prices on these tools because they weren't running, the sander is supposed to, the tablesaw is another story. but they didn't give them away either. Anyways, I think it might be time to sell a tablesaw. The truth is I loaned the Craftsman to a friend whose saw died. It's an indefinite loan, but I want it back when he's done with it...... could be years. And the Ridgid was my first shop tablesaw, a gift from my mom who has since passed away, I won't sell that, so that just leaves the Jet, (I'll keep that 12" Grizzly).Jack, good to see you are still around. Are you still in the barn that the snow came through the roof and covered your tools?
