I bought this Jet 1632 Drum Sander new in 2012. The original belt lasted about 5 years and the seam split. I ordered a new belt from Kingsspor and installed. The belt always tracked to the outside and would rub on the support for the platen. I tried every adjustment position but it always tracked to the outside. I reversed the belt and it still tracked to the outside. About a year ago I bought a new Jet branded belt at wood craft. That belt tracks to the inside and eventually rubs on the platen support. I tried adjusting the belt tracking screws tight on bothsides, tight on one side or the other and it still tracks to the inside. I loosened the platen support bolts and tried to move the platen left and right but the same problem exists. After adjusting the platen I tried adjusting the belt tension so that the belt just drives without slipping when I put my hands on the belt. Then adjusted the tracking bolts a little at a time on each side. The same result of the belt tracks to the inside. I am a very good mechanic and think I understand what makes the belt track but this one defies logic.
Any help of adjusting the belt on this sander would be of great help.
