I am making a jewelry box and it will have a carving in the top.
Posted is the picture I am working from.
I blew it up to get more of the details in my carving.
It turned out to be too big for my paper so I drew the missing parts out.
I used a sheet of carbon paper (yes, they still make that stuff).
I traced it out on what will be come the lid of the box.
Using my Dremel, I began to carve around the outer perimeters of the sketch.
I had many problems with the bit wanting to drift off of the lines.
My main problem is that the bit works well enough until I hit a growth line, then it wants to follow the line.
I have used several different bits and have the same problem.
Could be the speed of my dremel is not adequate.
I need to trace all the inside lines before I remove the material between the wings and such .
I have the little stand attachment for my Dremel and it works pretty good but still wants to follow the growth lines.
After getting this far on it, I realized that due to the fact that I have removed material from the outside of the sketch, that my attachment tends to want to tip into the voids and dig too deep.
I have redrawn it on a new piece of pine, and intend to cut all the interior cuts first. Since they will not be as deep as the outer perimeter of the sketch.
I hope this all makes sense.
I watch a UTUBE video of a guy using a very expensive device like the dremel and his cut like butter.
His device screamed as it cut and he was able to follow lines with no guide. He just wrote like it was a pencil.
Which is why I suspect that it has something to do with the speed that my dremel will reach.
Beside buying a new machine, does anyone have any thoughts.
I will get it done but the way it is now, one small mistake and the whole thing could be ruined.
I already cut the claws off the first ones toes.
Thanks guys
David
Thanks guys
David
