Jewerly Box w/ problem banding
668 Views 4 Replies 5 Participants Last post by  TwoSkies57
I started this long ago and because of the problem it sat on a shelf in the closet. But I've decided to try and fix the mess. I looking for suggestions. This project is based on plans from Woodsmith Magazine. The central inlay I purchased from Constantine's. The banding around the inlay I cut. I think what happened is that the groove wasn't deep enough and when I sanded the top I went thru in an area where the banding was a bit thinner. So.... 1) should I replace the whole strip or just the section that's bad? 2) should I cut out the banding to be replaced with a chisel or router? 3) I'm worried that I may damage the inlay and then I might as well put it in the fire box.
I'm not sure it matters but the banding is maple and the rest of the top is walnut. The central inlay comes right up to the banding. Under the inlay it's pw. Thanks for reading.
1 - 5 of 5 Posts
I'd say go with whatever way you are most comfortable with.
I would replace the entire strip. You'll spend far less time on that than you would if you tried to splice or blend in a new section and it will look better when you're finished. This, to me, is one of those 'cut your losses' moments where you just go ahead and bite the proverbial bullet.
As for which method to use I would go with what Theo said - whichever way best suits you and your experience.
David
Reactions: 3
I'd replace the strip also...
and I'd use a router plane to do it...
as mentioned... just go ahead and replace the entire strip...you'll be ahead of the game. AND be prepared to replace the remaining 3. There may be more color difference than you'll like when compared to the remaining 3 sides. As for method.what ever floats your boat. Router plane would work very nicely!
1 - 5 of 5 Posts
