I hope that clarifies the cut I am trying to make...
two ways..
gang cut on a table saw w/ dado blade...
jig base...
make two runners
set the TS at 15°...
rip a 2 by or thicker that is plenty longer than the total width of your ganged together pieces....
set the rips on their angled cuts on your material...
one runner is to the right side of of the dado held in place w/ clamps that look like this...
the sharp point (long point/LP) of the runner is set to cut line...
do the same w/ the other runner only use the short point/LP... the long point on this runner is to the far left...
drill 15° angled holes in the runner to receive the clamps...
set the other runner to the left side of the dado...
this runner is mounted on a piece of ply that has a 15° edge...
use the ply acting as a flange to clamp the runner in place....
place spacer blocks on either end of the the runners cut to the width of mortise to maintain spacing...
the runners carry the router...
maintain angle and act as guides for the bearing on the mortise bit.. or straight bit...
you could cut a closed end slot as wide as your mortise in a piece of ply w/ 15° sloped walls and mount both rails to that...
it would simplify things and help out w/ the clamping...
