Jig for the MilesCraft Turn-Lock Bushing
Here's a quick and easy jig to make if you have any of the MilesCraft tools.
The bushing can be hard to put in and take out,this jig/tool will take care of that in a snap.
Im not sure why they don't give you and I a tool to put them in and take them out but the need is there.
The suckers can be hard to get in all the way and once you do it's hard to get them out.
Because they are stamped out of high tech. plastic they don't fit that well.
Take a block of wood 3" long by 2 1/4" x 2 1/2" put one of the bushing on one end and draw the 4 ports holes on the block of wood ,then take a 1/4" drill and drill 4 holes ,1/2" deep,drive 1/4" wooden dowels in (don't glue them in,just in case you need to replace one,if you break one off)
This jig will work on all of the MilesCrafts Bushing 5/16" to 1"
http://milescraft.com/router/1202.html
http://milescraft.com/router/1200.html
I do recommend the Inlay kit,it comes with a 7" base plate unlike the #1200 6" base plate only with 2 TurnLock bushing, the 7" plate will fit many more routers plus it comes with a 1/8" carb. bit plus 2ea. TurnLock bushings for inlay work.
http://milescraft.com/router/1208.html
http://milescraft.com/router.html
MilesCraft tools ,just one of many spots to buy from: ▼
http://www.amazon.com/gp/product/B0...9234-8917508?_encoding=UTF8&v=glance&n=228013
http://www.amazon.com/gp/product/B0...8917508?_encoding=UTF8&s=hi&v=glance&n=228013
Just a NOTE****
We all know that Bob & Rick have great tips.the one below is a great one and should be one that you want to Bookmark or print out.
This one tip will save you hours of work..
when you want to setup your router table with a plunge router.
Shop Tips and News by RWS
http://www.routerworkshop.com/mark1.html?list=ME05--
Bj
Just a NOTE****
Bj
