spline it instead of rabbeting...
better face alignment. stronger, easier and less waste..
use BB for the spline...
BB = Baltic Birch...Okay, what's BB?
Hadn't thought of a spline. That would be a long spline, almost 1600mm long. Have you ever done that?
Would you cut both slots at the same time, i.e. have the boards both clamped and cut just the once running the cutter up the middle?
Evidently the material available is equivalent to maybe our 4' stock where his needs call for 1600mm (62.99213") length boards. Stick certainly gives you the methods best to use and as he stated the splines don't need to be continuous but need to be at both ends to be concealed. As Biagio asks, more information is really needed to determine what if anything else should be considered.You are asking how to make the boards longer not wider. The way it is done is with finger joints. You can buy a bit or do it on a saw.
https://woodgears.ca/box_joint/fingerjoint.html
/QUOTE]
I understand it to be that he wants a board 1600mm long and 450mm wide, but the standard width is only 405mm. Hence he wants to join two boards of 405mm along their long edges, and then cut off the extra. The question is whether to have the joint in the middle of the board, or to one side (i.e. one of the joined boards would land up being only 45 mm wide).
If this is the base of the cabinet, and not particularly visible from the inside of the cabinet, I would opt for the simplicity of the unequal widths.
to build for length an FJ butt joint is the way to go..You are asking how to make the boards longer not wider. The way it is done is with finger joints. You can buy a bit or do it on a saw.
use a slow set glue...I splined 2 seven plus foot birch boards together once for a mantle top using a 1/2” wood spline. You need to get the glue in as fast as possible at that length so more hands can be an asset.
he could FJ the length..You are asking how to make the boards longer not wider. The way it is done is with finger joints. You can buy a bit or do it on a saw.
/QUOTE]
that would make for a ferociously strong connection...
might want to think a bit more on using an RT... the board is a bit long for one and could easily become unwieldy...Given the sizes, I'd considr getting a 1/4 inch slot cutting bit--not expensive, cut the slot face down, or if you must do it freehand, face up with as wide a base as you can get on your router or at least an edge guide. This string has been very thorough.
Using a slower glue helps but even then the water in the glue can cause the wood to start swelling after a few minutes which can make a tight fit turn into too tight a fit. I think if I were to do boards that long again I would use a polyurethane glue (provided it has a long enough open time) and then spritz on the water needed for it to set and clamp it right away. I think the p u glue is less prone to make the wood swell than water based.use a slow set glue...
https://www.garrettwade.com/slo-set-glue-pt.html
Titebond Slow Set Wood Adhesive - Franklin Adhesives and Polymers
switch from yellow woodworkers glue (like Titebond or Elmer's Carpenters' glue) to a white all-purpose glue (such as Elmer's Glue-All).
Another option is to use a hide glue or a powdered plastic (urea-formaldehyde) resin glue.
Both of these glues set up slower than yellow glue and are just as strong.
go w/ an RF welder/curing...
PU glues has been discontinued here...Using a slower glue helps but even then the water in the glue can cause the wood to start swelling after a few minutes which can make a tight fit turn into too tight a fit. I think if I were to do boards that long again I would use a polyurethane glue (provided it has a long enough open time) and then spritz on the water needed for it to set and clamp it right away. I think the p u glue is less prone to make the wood swell than water based.
Interesting. Why has PU been discontinued? Environmental concerns or more basic reasons?PU glues has been discontinued here...
I like weldbond or RF...
