Jointech prob-need your help....
3702 Views 13 Replies 7 Participants Last post by  BenFlorida
Ok so I have a Jointech clincher router fence system. It’s been a great tool and still is. I’ve made literally thousands of projects over a 16 year span with it. But unfortunately when I moved from Sacramento to Nashville 5 years ago....somehow the true center plastic template strip (inserts in a track in the fence) didn’t make the move!? On that strip there was a carrot symbol that was part of the precise alignment plan when creating dovetails. I know Jointech is out of business. And I’ve tried unsuccessfully to ‘find’ this little template strip-no such luck so far. So, for starters if anyone knows where I could get the true center strip that inserts into a track in the clincher that would be great. Or if any one knows how I can effectively set up the tool for perfect dovetails without that mysterious little plastic strip that would be soooo helpful. Thanks for your help and time. Jim
1 - 14 of 14 Posts
Hmmm, Incra bought JT (or their technology). I have bits and pieces of some sort of jointech fence that I bought at an auction. I think you are talking about the standard template strips that are about 1/2" wide. My Incra LS came with something that sounds like what you are talking about. I know the incra templates fit the JT fence. Don't know if they sell the templates separately. You could call their support line - they seem to be pretty generous with their help.
Now, it's also possible to print your own templates, maybe you could make an alignment strip.
Reactions: 2
Agree with Phil. If Incra has anything that will work they'll make sure you know. I've had nothing but very good support from them over the years. See if this is what you need Master Reference Guide with Templates, Incra MTL2
BTW. welcome to the forum.
I'm thinking the centering guide he's referring to is part of the base machine and not part of the template set but that's just a 7 year old recollection of a minor memory. The Incra folks will know for sure.
By the way, anyone who is thinking of building a router table for an Incra LS that uses those templates, make sure you plan a BIG drawer to store that book - it's fricken HUGE. Mine barely fits and the drawer is pretty big. I don't see the need to print full sized joint drawings - wish they had a small reference book instead.
You say that now, wait another 10-15 years when the eyes are a bit weaker.:crying: Build a shelf above the router table like I did. I can still reach the shelf........I also keep the DVD handy for those times I haven't used it for a while as a great visual refresher.
I wanted to "like" your post but don't like the reality of aging.
Jim
have you got a picture what you are looking for
I have a jointech maybe we could Duplicated
Could someone take their strip to a copy place. Or, if the have a large scanner, scan it. It's only about 13" long. But, if Incra's strip works, that's the best bet.
Thanks for finding that post Doug. It doesn't contain the centering scale, though. Here's a photo of the incra autocentering scale in my LS25. You can see that it is half size - 1 inch is 2 on that scale. The way it works is
  1. You set the fence to zero so the bit is just shy of cutting.
  2. Measure the width of your wood.
  3. Slide the scale to the size mark for your bit. (don't move the fence, just the scale)
  4. Move the fence to the wood width on the scale.
Kind of cute but I never use it, preferring to do the math in my head. Do step 1 and 2, then move the fence 1/2 of the wood width plus 1/2 of the bit size.
To reproduce the scale, make a scale that is 2:1 (ie, one inch length is marked 2") and then to the right of 0, mark fractions with the same 2:1 ratio - 1/4 would be marked a 1/8", 3/8 at 3/16" and so on.
https://www.incrementaltools.com/category_s/362.htm
incra auto center scale is $2 on their website, plus postage. Might be worth a gamble?
part number PSCA-AC "Lexan Scale, Auto Centering"
I'm pretty sure it will work. But, it looks like the original posting was just a "drive by shooting". Or, perhaps "one and done" is a better description.
Jim, You do not really need the template you are seeking. I have a JoinTech and have used it for years. This template has broken due to extended use but here is how you do the same thing using a standard scale on the Clincher.
1) With the bit outside the fence, slide the fence to just touch the widest point of your router bit.
2) Set a measurement scale to show your bits diameter under the curser hairline. You can use any point on the scale but remember this is your set point and the carrot would be right of this point. I typically use 0" point on the scale as my carrot so for a 1/2" diameter bit I would put 1/2" (left of scale zero) under the hairline.
3. Place the workpiece between your fence and the router bit (right side of bit).
4) Move the rabbit to 0 on the scale or point you used as your offset.
5) Remove workpiece and slide fence so the rabbit is under the curser hairline.
6) Your workpiece is now centered on your router bit.
3)
Failed to mention if your templates are starting to crack and break, the Incra templates will work just as well as the JoinTech. I bought the whole set along with the manual just to have a reference for them as well.
1 - 14 of 14 Posts
