Using a router to joint the edge is doable on a router using either a router table or handheld router.You Tube Video Except for a router sled for flattening/planning I don't know of a way to joint the wide side. An over the top/expensive sled
Yes, I’m thinking more for edge jointing. I’ll likely still use my jointer for face jointing.Using a router to joint the edge is doable on a router using either a router table or handheld router.You Tube Video Except for a router sled for flattening/planning I don't know of a way to joint the wide side. An over the top/expensive sled
A properly set up table saw and a good blade will get the job done. I personally just use my planner and run the board through on its edge. I sold my jointer years ago and never missed it.
I'm confused why you can use it for edge jointing?
Why would I buy rough? We buy rough when it's necessary, but not for a majority of work.I don't like to be critical, but why would you buy boards that have factory edges and are already dimensioned? I'm lucky to have a great local source of rough lumber, I can and have had them edge and dimension lumber for certain projects. No, I don't have all the fancy woodworking tools, just a few basic ones can get the job done quite nicely.
Take care all.....
I don't buy at a box store. I buy from cabinet supply companies. We have Liberty hardwoods and Paxton lumber company within an 30 minutes of me.
Mgmine.... where do the cabinet shops get there materials from around you?
All lumber come is rough at the warehouses. It's processed for free before I get it.
