" in the real world"?
Is this the world you live in or the rest of us.?
Back to your post #12 . I wouldn't recommend butt jointing. I have the same issue considering putting addition hardwood in a beroom.. routing for a spline is the way I know to do it correctly..I won't argue the point I only hope the poster understands that the end groove is not necessary and that he doesn't try to somehow put a groove in the existing boards. I will leave this last video in hopes that it will help others understand how to do a floor repair in the real world.
Project House: Wood-Floor Repairs, Ep. 4 - Installation - Fine Homebuilding
In this video, Scott Sidler teaches Justin about his selection method for choosing boards and guides Justin through the installation.www.finehomebuilding.com
So, I’m really scratching my head here. Where in that video you posted does it say anything about butt joints ?I won't argue the point I only hope the poster understands that the end groove is not necessary and that he doesn't try to somehow put a groove in the existing boards. I will leave this last video in hopes that it will help others understand how to do a floor repair in the real world.
If he’s talking about vinyl or laminate flooring then yes, they have tongues/grooves on both ends. But then, he a) doesn’t understand the difference between hardwood flooring and laminate and b) who the hell routs laminate slats ??Back to your post #12 . I wouldn't recommend butt jointing. I have the same issue considering putting addition hardwood in a beroom.. routing for a spline is the way I know to do it correctly..
Is it possible your talking about thin laminate flooring?
I guess you'll have to ask the one who brought it up..If he’s talking about vinyl or laminate flooring then yes, they have tongues/grooves on both ends. But then, he a) doesn’t understand the difference between hardwood flooring and laminate and b) who the hell routs laminate slats ??
Sent from my iPhone using Tapatalk
Either you or I am missing the point. Is part of the floor already installed? When talking about reversing direction I am talking about one floor going horizontal and the other going vertical. Is Jamma007 trying to install additional flooring that has a tongue on it to flooring that does not have a groove? If so, then good luck (especially for a non professional) to cut a groove/ slot into the existing floor. I would really like to see that slot when it reaches the wall. Maybe it could be cut with a chisel and an oscillating tool or maybe it could be cut with a kick saw or maybe it could just be only cut where it's easy to cut and then simply butt up the rest. Maybe if it was really necessary to have a slot then the guys in the above video doing boarders should be told that they are doing it wrong. The end tongue and groove help keep things lined up. A surface nail and adhesive will do the same thing.
Put a threshold over the seam to hold it down ?The issue with just a butt joint here is that there are many different boards that may move over time and start to come up. A slip tounge will help them all stay flush.
I did, but I was just doing a test fit for my cuts. I always use roofing felt.You didn't put roofing felt down before installation?
