1 - 13 of 13 Posts
· Registered
The preview screen won't show any bit that undercuts (keyhole or dovetail) but all you need is a short 2-segment vector that runs back on itself and a profile toolpath ON the line. Describe the bit as an end mill but name it a keyhole bit.
Sometime the software wants to close vectors that end on the same point they started at. I get around that by making a very slight V instead. This will taper the keyhole slot slightly but that just make it easy to find/slip over a screw in the wall. I normally run a straight end mill which has the diameter of the narrow part of the keyhole bit to clear out the center. Less work for the keyhole bit to cut the final shape.
· Registered
signmaker
Couldn't get any easier than that.
Although w/ an ATC cnc, I usually plunge in a 1/8" straight to get that
opening shape. Then follow up w/ the keyhole down, thru, move a .005" over
then return, keyhole up. Just like the video said. Hmm... never did the plunge method.
I will admit I did the one way method ONCE in pvc. The vacuum table won
and kept the sheet down, but I had 2 big holes.
? Is it possible to ramp inward then return? Enroute for me doesnt ramp
so I dont know and Vectric doesnt show it like the guy said in the video.
· Registered
You wouldn't want to ramp from the surface to the bottom of the dept of the cut. I've done a couple where I used the fluting toolpath to start 1/4" deep, ramp another 1/32" or so, then ramp back to the starting position before retracting from the wood. That was when I needed the screw to get tighter as it slid up the keyhole slot.
4D
· Registered
I use the Keyhole Toolpath Gadget that is built in to Vectric VCarve Pro and Aspire ( VCarve Desktop may not have Gadgets). Once you have it configured with the size of bit you are using and the orientation of the keyhole, it is an easy cut. It saves your settings so it is ready the next time you need a keyhole.
Can't get much easier than that.
Jay
· Super Moderator
Jay
I have used it. Works great.
· Super Moderator
If you have room, you can draw an arc. The bit will enter at one end, cut your desired depth and length, then exit the other end. Then all you have to do is hang your work piece and adjust as necessary to get it plumb. Saw it on a group post on FB.
· Super Moderator
Here is my arc'd keyhole slot. I made it 3 inches long (on an 18 inch dia circle).
Using a keyhole slot cutter, there would be a hole at each end for the screw head to enter/exit.
Edit: Added pictures of actual keyhole slot.
· Registered
signmaker
... I've done a couple where I used the fluting toolpath to start 1/4" deep, ramp another 1/32" or so, then ramp back to the starting position before retracting from the wood. That was when I needed the screw to get tighter as it slid up the keyhole slot.
4D
Thats what I meant, ramp downward then return ramp back up.
Dint word it right.
Thanks 4D
1 - 13 of 13 Posts
