Hey all, I had to update my stove and microwave,so I ended up buying a fridge too, only because it’s $100 more to buy white appliances?
Anyways , I don’t know what I should do here . If you see the one pic , the alarm panel is on the right hand side of the fridge , and I don’t want to relocate it , so the fridge is as far right as it can go .
Best case scenario would have been to have a cabinet on each side of the stove obviously,but I don’t have the real estate.
What happened was I had the fridge against the stove by an inch , only because the cabinet above it didn’t fall so short . But I can’t get the microwave door open as it must be grabbed from the right hand side .
So I moved the fridge over which created a 4- 1/2 “ gap between the stove and the fridge , and although that’s where I want it, the cabinet above the fridge now falls short by the same amount and doesn’t look very aesthetic.
So in the second pic, my idea was to either just replace the 30” cabinet with a 36” cabinet , or add a 4” spacer between the two cabinets , and add a 4” cabinet below that spacer which would slide towards you concealing spices . The pieces I want to add are in red , and the black square represents the 30” cabinet moved over .
Any suggestions are welcome
Just a heads up , I have to build a cabinet beside the left hand side of the stove so I have a counter top there . I only have 19 inches deep unfortunately, so I have to custom build it. There’s a doorway to the left , and going the same depth as the stove would start blocking the living room entrance .
