Decent price.... HVLP spraying only with that CFM
Yea but I mostly be doing small projects mainly.Decent price.... HVLP spraying only with that CFM
I understand that but I have a small shop and well I wanted something a little bigger. I have a project coming up that will require me to use a 1/2 inch impact so I needed something a little bigger. Plus I know a few tricks I learned using HVLP sprayers so this will do in a pinch on small projects and I am not planning on lugging this aroundI would just buy a pancake compressor and be done with it . I had a 5.5 cfm @90 psi with a 20 gallon tank, and found it didn’t run any of my tools other than my nailer .
I was basically just lugging a lot of weight around for nothing .
Mine could not even run an air drill long enough to put a 3/4” hole in a 2/4 . Has to wait for five minutes for it to recharge.
If I do this again it will be an 80 gallon tank with a 5hp motor and rated for a bare minimum of [email protected] .
I just found mine didn’t help run anything better than my pancake compressor. Hopefully you’ll have better success .I understand that but I have a small shop and well I wanted something a little bigger. I have a project coming up that will require me to use a 1/2 inch impact so I needed something a little bigger. Plus I know a few tricks I learned using HVLP sprayers so this will do in a pinch on small projects and I am not planning on lugging this aroundI have a 6 gal porter cable pancake if I need to air up tires or use a nailer outside
