1 - 3 of 3 Posts
KOMO VR510 MACH ONE CNC ROUTER
NEW: 12/2000
CONTROL: GE FANUC 210i-M CNC
SPECIFICATIONS:
TABLE DIMENSIONS............... 60" X 120"
X-AXIS TRAVELS................. 131"
Y-AXIS TRAVELS................. 78"
Z-AXIS TRAVELS................. 6"
SPINDLE TAPER.................. BT30
SPINDLE SPEEDS................. 18,000 RPM
SPINDLE MOTOR.................. 12 HP
NUMBER OF TOOL POSITIONS....... 8 TOOL ATC
............................... 20 SPINDLE DRILL HEAD
FEEDRATE/TRAVERSE RATE......... 1,250 IPM (X & Y), 1,200 IPM (Z)
EQUIPPED WITH:
QUINCY QSVI 40, 40 HP VACUUM PUMP
AGGREGATE SPINDLE (SECONDARY DRILL HEAD/SPINDLE BORING BLOCK):
--- (14) VERTICAL DRILLS AND (3) DOUBLE HORIZONTAL DRILL
--- TO UTILIZE ABOVE AGGREGATE SPINDLE HEAD -- KOMO POST PROCESSOR REQUIRED --
------- THIS POST PROCESSOR MUST BE PURCHASED SEPARATELY
** MACHINE IS IN PLANT, UNDER POWER.
** AVAILABLE FOR IMMEDIATE INSPECTION AND PURCHASE
** MACHINE IS SET UP FOR WOOD ROUTING
** WITH COOLANT SYSTEM (IF PURCHASED SEPARATELY) CAN BE USED FOR METAL
**INCLUDES CASE FULL OF NEW AND USED BT30 TOOL HOLDERS AND ER32 COLLETS AS WELL AS EXTRA MACHINE CONSUMABLES
** HOURS AS OF 6/23/2015: 2,724 HOURS
----- AT FULL PRICE, SELLER WILL DECOM AND LOAD ON BUYER'S TRUCK!
Price: $56,000 Loaded on your trailer.
FOB: Maize, Kansas
Matt 316-265-8335
Discussion Starter #3
For some reason the pictures would only upload 4 at a time. Each time I tried to load all of the pictures at the same time, the progress bar would show 100% but would not show on the post. Weird.
1 - 3 of 3 Posts
