Hi guys,
i have a question for you,i would like to purchase a laminate trimmer like the Porter Cable for example,not only because i think is very handy for routing mortises for hinges,but also because i would like to use it together with a slot cutter bit for cutting grooves in some kitchen cabinets that i´m going to make,so i can attach the face frames with biscuits,now the question..is the laminate trimmer powerful enough for this job?and if it is enough,what model/brand should i consider?hopefully you guys will help me with the answer..
thank you!
thank you!
