What type of laser are you using? I asked the epilog guy at one of the trade shows and he was unsure how clean of an edge 1/4 in thru cuts would leave. What other materials have you tried cutting templates out of?
I prefer to use guide bushings for templates that are going to be used over and over. I've had too many times when using a bearing guided pattern bit that I have damaged the template. It is much harder to do that with a guide bushing.
Depending on what I'm doing, I use different size combinations of guides and bits. For edge work, I usually use a 1/2 in bit and a 1 in guide. This makes calculating offsets pretty easy.
