Guys , I'm installing three 5mm white led's in the top of my Tub/ shower niche .
I've drilled 3/4" holes threw the wooden studs above the niche , and will be drilling small holes in the ceramic tile to slide the led holders in place .
My concern is mold due to condensation. I was thinking of putting fibreglass resin in the perimeter of the holes in the wood in order to make the wood waterproof , but that stuff is sure smelly .
Anything else you'd recommend to coat wood with to make it waterproof? It shouldn't get wet there , but the potential for condensation is pretty high.
Here's a pic of the back side of the wall where the wire will go down into one of the three holes . I can seal it on top of the hole easily enough once the wire is put in
