Don, I am not home, so I can't look at my 1200, but I think the plate is just a piece of sheet aluminum or steel. Hopefully you have the carriage pieces that support the baseplate and engage the lead screwI am searching for the router plate that would mount to the y axis rails for the 900 series. I cannot find replacement parts for any legacy ornamental mills. Thank you Don.
The tap is something that was recommended ok a legacy mill user group, I haven't tested it yet. I won't be near my machine until mid November, otherwise I would run out and measure it.Thank you, the tap you posted 5/8 x 4 is the correct tap needed for the mill rod? Im in uncharted water when it comes to machining. I need to research where I can find Dublin. I will keep you updated on my success. Thanks again.
Are you selling other parts? I'd be interested in the head and tail stock?I might have some parts for your application?
Hey CS Log Rescue,I might have some parts for your application?
I might have one? Send a picture of it? ThanksI am searching for the router plate that would mount to the y axis rails for the 900 series. I cannot find replacement parts for any legacy ornamental mills. Thank you Don.
Do you still have parts and do you have a Drive Motor? w
