All the bulbs of that type that I have found are low voltage- I crashed into a total dead end looking for a replacement bulb. The bulb part number 144407-00 is obsolete and not replaced by any number bulb I could find. Likely as not you won't get much joy from B&D either. Sadly, no luck finding a picture of the bulb or voltage either to find a non-B&D substitute.
- might have better luck fishing a used one out of the 'Bay' and have a light and spare parts ...
b&d 7614 in Routers | eBay
- ebill
Part is #144407-00. Reference #74. Shows obsolete from B&B. Depending on the wattage, you might be able to use a You would have to remove the bulb and check to see if there's another # and the watt. If you have a Radio Shack in your area. They may have a bulb to match. Looks vary similar to a GE 194.I have an older B-D 7614 and the small wedge shaped light bulb in base is blown. Does anyone know where and how to purchase a new one? I am awaiting a reply from B-D currently.
