Saw that bit, but Rick & Bob have shown a locked rabbet drawer drawer joint using just a straight bit. That's what I'm looking for.del schisler said:look on the right side Is this what you want? drower joint http://www.mlcswoodworking.com/shopsite_sc/store/html/smarthtml/pages/instruct.html
Just tried it again and was able to get it. Sorry about that. Must be those Senior Moments!beemerbob said:Just what I was looking for. Thanks, Bj3. Couldn't open the right hand thumbnail, however.
I finally found the tape that came with my set of spacer fences. A picture IS really worth a hundred words.Joe Lyddon said:It seems like I remember them doing it in a real simple manner using one of their Spacer Fences...
I found my notes!!
Using the 1/4" Spacer Fence setup as for box joints... and a 1/4" straight bit.
Make a spacer block for Cut #2.
Use backer / pusher blocks behind each cut.
Cut #1:
FRONT piece good side UP... flat on table...
Make the cut... a groove 1/4" x 1/4" and 1/4" away from end.
Cut #2:
SIDE piece. Clamp spacer block over the Spacer Fence.
Hold piece on end with the good side toward the fence.
Use a scrap block from the side to hold piece solid against the fence.
Make the cut.
Done!
Slicker than you know what!![]()
I found my notes!!
Cut #1:
Cut #2:
Make the cut.
Done!
Isn't this what Rick calls the combination joint on the show? They show the Jewelry Chest project all the time on the WWchannel and the case sides are constructed with this joint I think. Basically one panel gets routed flat and the other on edge.bobj3 said:Hi Joe
I need help on this one![]()
Is this what you mean,see below,, quick box joint ,,,but I don't see the LOCK for the drawer front or did I miss something.![]()
Bj
I took my notes from an episode on the ww'g ch.challagan said:Isn't this what Rick calls the combination joint on the show? They show the Jewelry Chest project all the time on the WWchannel and the case sides are constructed with this joint I think. Basically one panel gets routed flat and the other on edge.
