1 - 15 of 15 Posts
Discussion Starter #1
I have built a router table around my Triton MFO01 router, and have started to use it.
I discovered that the crank handle for the built-in lift mechanism isn't long enough to clear the fence when using a tall (long) bit. I discovered the problem when I was routing a T-slot. I used a 1/4" bit to cut the slot, and came back with the T cutter. I did not want to move the fence for obvious reasons.
When the bit requires that the router be lowered very much, the fence interferes with the crank handle rotation.
I tried making a new one from wood, but by the time I drilled out the 7/16" dowel to accept the centering pin on the router body, the wood was so thin that it broke on first use.
Suggestions? Triton does not offer a longer crank that I can fine.
A Fellow Woodworker utilizes a socket wrench handle and a long extension holding the allen screw when raising or lowering the router.
Not sure of how the Triton is set up, but it might work.
''T'' handle Allen wrench???
Sounds like a craftsman router I have one that works that way.
For the Triton, 1) remove the crank handle. 2) Drill hole in the end of a block of 5/4 X 5/4X8". 3) Insert Triton crank
Mine hangs from magnetic bar so I also attached a washer. I made from 5/4 so it was grippable
I would use a length of alloy tube the same as the original and fit a handle onto the top. You could then make it as long as you like.
add one of these to your Allen shank..
or one of these w/ a ¼'' drive ratchet.......
Discussion Starter #9
The Triton routers use a shaft about 1/8" dia with a pin through it. The stock wrench has a hole in the center with a slot across it.
I think Paduke's suggestion is going to be best. I'll look at taking the crank off the end of the shaft.
Thanks,
I would think that if the router is mounted such that the height adjustment is at about the 4:30'ish position, it would be out the way of the fence...?
This would put the gross adjustment at about 3:30'ish (right hand) with the switch at 9:00'ish (left hand).
If it's already mounted this way, then the other offered options might be needed. If it isn't, you could try it and see if you like it...
I don't use the above table adjust so my Triton is mounted diagonal (SW/NE) with gross height operated with my left hand.
Discussion Starter #13
I wanted the spindle lock and power switch in front, so I mounted the router so the crank ended up on the left side of the spindle, and too close to the fence.
Because I didn't want to disassemble the router to disable the power switch-spindle lock interlock, I wanted easy access to the power switch, so I can turn it off when changing bits.
But, thanks for the suggestion.
You may find that you can still reach under the table, as I do, and adjust with the handles....
1 - 15 of 15 Posts
