Looks pretty good, Oscar! 3/4" is pretty thick but not a problem. What diameter is that?
David
David
I made one a few months back, bought the rubber stoppers and put it together with 3/8" bolts that were too big, 1/4" were too small. What's the width of the slots supposed to be? Thanks.Its 9 inches. My mini lathe only has a 10" capacity and my larger lathe has a 12" capacity so I'll be able to use on either one.
1/4" is the way to go. I cut my slots 0.260" wide.I made one a few months back, bought the rubber stoppers and put it together with 3/8" bolts that were too big, 1/4" were too small. What's the width of the slots supposed to be? Thanks.
I figured you might experience that, Oscar. I've read of people using 3/4" MDF or plywood and the chuck being so heavy that it caused issues.It torqued the head stock to unscrew itself due to the weight of my Longworth chuck. Using 3/4 inch material probably not the best choice.
