Another idea that I use quite often is to make a small miter box that fits the width of your material and use a Japanese pullsaw to make the cuts, you will be surprised at how accurate you can cut miters.
Hebr
Hebr
Thanks again Stick. I didn't know what an LA plane was and my first google attempt tried put me on a plane to Los Angeles. Then I tried LA Wood Plane and found out it stands for low angle. I'm almost afraid to ask you for a reasonably priced recommendation because you seem to deal in only the highest quality stuff. But I'll give it a try. Can you recommend a reasonably priced LA plane such as the least expensive one that you would still recommend?yur shooting board...
do not use MDF... over time thinks and hardware holding power will fail...
use a LA plane w/ it because of the end grain...
make sure there is no sawdust build up against the fence...
trim one end of every piece...
set a stop block to control length to maintain lengths...
use your clamp to hold the piece... more fool proof..
I like this style...
Sie haben richtig DerSchuhmacher! There's a cadre of active members on this forum that are very generous in sharing their knowledge and it's much appreciated by those such as me who are trying to learn.Wow, there's a lot of good information in this post!
New name for Desert Rat Tom - which is too unbecoming for him.Wood River V3.
My 25 cents. - D.R. Tom
DesertRat actually describes my usual appearance around home and workshop, although I clean up pretty well for work and my senior group, and if I'm taking my sweetie out. And it helps keep me humble, which is very much necessary, according to my sweetie.New name for Desert Rat Tom - which is too unbecoming for him.
How bout we start using .......... Dr Tom
That's the way I see it, you need to be comfortable in the shop and relaxing around the house. I usually put on nice clothes to go anywhere except the lumber yard , home center or somewhere like that and sometimes even for them.DesertRat actually describes my usual appearance around home and workshop.
