Thanks for the info, I'll look into it!
Ok, I made my decision. After doing much research and seeing that a person could spend ALOT of money on a cnc router, I felt that the Zenbot 4848 was the best bang for my buck at this point. After all, this venture could flop on its face, and if it does, being out $2,000 doesn't sting as much as double that, if not more than double.
It took a little over a month to get the machine. Apparently they are built to order. It arrived in 2 boxes (each box was approx. 100# ea.) and some assembly was required. Actually, ALOT of assembly was required, but what should I expect for $2000?
There are 2 drive motors for the Y axis (labeled Y & A) and apparently the ports were accidentally switched in the control box because my up & down arrows on my keyboard were backward. After I switched the wires at the motors, my arrow keys moved the head in the correct direction on the Y axis. Other than chasing a few tapped holes to get the bolts to go in some holes, that's the only issue I've had so far.
I bought Mach3 & VCarve Pro (another $750) to run the machine. I've only cut 1 programmed pass so far but can see that the result was positive enough to say there's promise here.
So, that's where I am. I just wanted to give feedback on this post that I started. I don't like it when a post is started and then there's no feedback. If a person is going to do that, then why even start a post in the first place? Don't get me started. Anyway, thanks to all who have contributed to my little venture. God bless you!
