1 - 8 of 8 Posts
Gday guys,
I am having trouble getting my cnc to do what it is told.
The machine works fine when operated manually from Mach 3 but when I try to run a G code file it goes to the G54 without a problem but then goes straight through the workpiece.
Below are the steps I take from beginning to disaster.
1. Home machine ( zeros on all axis in DRO Machine Coords )
2. Move spindle to centre of workpiece ( zero all axis on DRO )
3. Regen toolpath.
4. Move spindle away and hit go to zero to test G54 OK.
5. Enter spindle speed and hit Cycle start.
Result.( I removed the workpiece just in case )
1.Spindle does not start. ( Spindle used to start before G Code modification )
2.Spindle goes to top ( Home limit )
3.Spindle decends to machine bed and starts to go through program.
cheers
Trevor
Super Moderator
John
Hello Trevor.
welcome to the forum,
Welcome to the forum.
Ross
Welcome to the forum Trevor.
Discussion Starter · #6 ·
Mach3 probs
Gday guys,
the source of the G code is Vectric Aspire.
Its on my workshop computer so I will post a screen shot tomorrow.
The G Code is a smile circle .
cheers
Trevor
Discussion Starter · #8 ·
Mach 3 Problem
Gday guys,
Please find attached the simple circle G Code I am using for a tester.
G Code produced by Aspire.
Hope you can cast some light on my problem!!
cheers
Trevor
1 - 8 of 8 Posts
