your emergency stop (e-stop) button may be pushed in. try rotating it to see if it will pop out. that may get rid of that ...
the machine doesent have a emergency stop switch. the company that moved it to storage disconnected some wiring.Did you click the Reset button? If you don't get it out of reset, nothing else is going to work. You need to figure that out first before messing with anything else.
i know i need one, will figure out where to connect to circuit board.
No, it does not. You may just need to toggle the active low setting of the estop input to get it to reset with no switch attached.I believe Mach requires an input for the estop in order to reset.
Hi Ken, take it one step at a time, Mach3 is a little confusing at first but you will get the hang of it. After you start getting progress, back up the entire Mach3 directory to a USB drive. Keep copying the directory as you improve the setup. Also write down motor control settings, the Step/Dir/Port settings etc. The last thing you want to do is to redo everything should the PC crash...i ordered a new ess board, when it gets here i have a it guy that will help me delete mach 3 and reinstall it correctly and
configure for ess board. than will have license code resent. at that point i should be able to go foreword with the
setup.should know within the week.
That's not a good idea at all, good that you're going to change it. I guess it depends on how robust the 48v power supply is relative to the current draw of the steppers as to whether it will handle all three steppers. Z typically doesn't run as fast as X and Y so is there a problem with the Z axis as it is now on 36v?used the shield as a connection
