Mach 3
882 Views 9 Replies 6 Participants Last post by  maddog
I am new to CNC routing and having problems setting up my newly built machine. I built a 2ft X 4ft "Kronos Robotics" design running Mach3. I live in Prescott Valley, AZ and am looking for someone to assist me in the issues. Any help would be greatly appreciated.
1 - 10 of 10 Posts
Photos always help getting better and more responses. What issues are you having, how far have you gotten, what steppers and components are you using, etc.?
The controller is from CNC Router Parts running Nema 34 steppers. The spindle is also from CNC Router Parts which is a 220v, 2.2kw unit. I also have a "Wix HD pendant. I guess my main problem is the verbiage in the instructions and understanding what items are to be checked on or off. I am running two motors on the Y axis and not sure what is to be on or off within the "ports and pins". The machine is probably 95% done, I still need to get the 220v to the spindle, but virtually done. Since moving here from Pine, AZ I have not gotten the motors to operate and at this point, my Mach3 does not see my "ESS" as being attached. Just a number of small things. Thanks for your time,
Dee Strubhar
Welcome to the forum @Dee S
Moved to CNC forum for more visibility on Mach3.
Welcome to the forum, Dee.
i set up a plasma table using mach3, if you don't get the info you need here, the mach3 forum is very helpful
Machsupport Forum - Index
Dee Strubhar
You may want to check with CNC Router Parts as the probably already have a .XML file that you can just drop into your Mach3 folder and have you up and running, If not, first you need to make sure you have the ESS_Mach3.dll file in the Plugins folder of Mach3. Then under Config > Ports and Pins > Motor Outputs you're going to enable X, Y, Z, and A axises. You also have to Set a Step Pin # and a Dir Pin #. Use the following: X = pins 2 & 3, Y = pins 4 & 5, Z = 6 & 7, A = 8 & 9 and make sure you have a Green Checkmark for each Axis. The Step Port and D1r Port will all be set to 1. For your Spindle Step Pin = 1 Dir Pin = 0. Step Port and Dir Port = 1. To run your Y & A together you go to Config > Slave Axis > Y Axis column and click on A Axis. Under your Spindle Setup you'll need to Set your Spindle (Clockwise) Output# = 1, and under Output Signals make sure Output#1 is enabled (Green Checkmark) and the Port# and Pin# are also set to 1. This should get you at least up and running.
Thank you, I'll go back thru and see where everything is checked. I thank you for your time, you're a gem.
1 - 10 of 10 Posts
