Hello to all Master in CNC.
May I ask your help about my Mach3 (photo attached) we don't have problem in XYZ Axis our problem only is we can't measure or no voltage output in OUTPUT 1-4 where in the connection is for Spindle motor.
The first step I measured the voltage across the IC and connect to (it seen like Diode) and we measured 7v , but to measure in terminal wire no voltage output.
I hope you can give advice how to troubleshoot this.
