Mike, or anyone else with the answer...
I want to make a Magic Box.
I use the Box Calculator:
A. Length... 12
B. Width..... 10
C. Height..... 6
D. # of boxes... 1
E. Material Thickness... 0.5
Gets results of:
2 12" x 10" x .5" Top & Bottom
2 12" x 5.5" x .5" Long Sides
2 9.5" x 5.5" x .5" Small sides
I want the finished size to be 6" high... from bottom to top...
According to the Plans of the Magic box, there is a 3/8" groove around the Inside of ALL Sides. When the box is all glued-up, another groove is cut around ALL sides so that the Top Lid is created which closes nicely into & over a nice fitting lip between the Lid & bottom section of the box.
Question:
As a result of those Side grooves, Inside & Outside of 3/8", wouldn't that cause the Height of the box end up to be about 3/8" shorter than the 6" I want? Therefore, requiring and additional 3/8" to be added to the Ht. of each Side to get a finished result of 6"?
Am I correct in my thinking?
Am I missing something?
Sure is a COOL project... :yes4:
Thank you very much...
A. Length... 12
B. Width..... 10
C. Height..... 6
D. # of boxes... 1
Gets results of:
Question:
