1 - 8 of 8 Posts
The Router Guys
Discussion Starter #1
When building cabinets or shelving, you require a dado cut to hold the shelves. Often the size of this board can exceed the size of your router table. In this router tip we will show you a safe and easy method of cutting a dado in a long board. When using a table fence and cutting a dado the fence is always on the right hand side to ensure the rotation of the cutter pushes the stock into the fence.
Click here to see today's tip
Another way to do it is to stand a piece of the material on edge where you want the dado. Clamp 2 straight boards against the sides of the piece. Remove the standing piece and use a flush bit with the bearing using the 2 pieces as guides. You dont need to worry on sizing this way.
This tip addresses the exact problem I will be working on as soon as I get my router table built so that I can work from my wheelchair. (I am also known on the forum as th-alton. Ask my computer or the routerforum server why I have two screen names.) I am building shelves for my office using 2 x 10 sides and 1 x 10 shelves with variable and changeable shelf spacing. My plan is to make jigs and use a hand-held router. I am still debating whether to simple make 3/4 wide by 3/8 deep dados or use a 3/4 radius round nose bit and round the ends of the shelves with a 3/4 daimeter bull nose or 3/8 radius roundover. Any suggestions?
mftha
You may want to take a look at this jig, it works with out errors.
And it's a quick and easy one to make...just need some 1/2" or 3/4" MDF stock, put in a slot and you have the jig. see snapshots....
http://www.routerforums.com/showthread.php?t=2711
Bj :)
Bj :)
bobj3
Thanks. As a result of your suggestion I am rethinking my procedures. (very high praise from me) However, I already have the wood at the final width, and I have no table or circular saw so I cannot cut a dado in 2x wide stock then rip it in half.
Hi mftha
You may want to take a look at this Grizzly Saw, It's a great saw and I use it all the time on plywood 1/8" to 3/4" , 4' x 8' can be a pain to cut up and this little saw works great for that and many other jobs.
G8598 18V 5-1/2" Cordless Saw Kit
http://www.grizzly.com/outlet/G8598
Bj :)
1 - 8 of 8 Posts
