ain'ja reading the how to posts here Rick..
For some reason I don’t recall seeing using the factory insert as a jig . Gotta start paying attention ,but being autistic it’s tough some daysain'ja reading the how to posts here Rick..
I’m liking the hot glue idea . Never thought of that oneThat's what I do. I add a couple of drops of hot melt glue to a piece of mdf and stick em together and then either use a pattern or flush trim. My unisaw takes a fairly thick insert and it has set screws to level it with the top. The mdf threads just fine for the set screws and there is enough friction in the threads to keep them turning in use. I made about 6 last time I made some. Then when I use them I write in felt tip on the underside which blade and whether I used stabilizers etc. If you were making zero clearance for a dado set you could have one for every width stack you use.
Well maybe I need a scanner and a 3D printer :grin:Yes, it is. It stops the plate from lifting, getting caught by the blade and firing it back at you.
Bet I could make 100 or so before you got the pattern into the software. :wink:I was thinking using the cnc when it’s up and running , but you’d need the perfect fitting vector first .
May be able to pull it off in Aspire if the ends are actual circles
Bet you make 1000 before my garage is you know whatBet I could make 100 or so before you got the pattern into the software. :wink:
Note that I carefully sidestepped that bit of nastiness. :grin:Bet you make 1000 before my garage is you know what
Rick, I have the sneakin' suspicion that the world will have moved on to something new by the time you get up and runnin'. Just a hunch, mind you, I was wrong once before.I was thinking using the cnc when it’s up and running , but you’d need the perfect fitting vector first .
