Say hello to my little friend, no I’m not referring to Tony Montana’s machine gun, I’m referring to Makita’s BDF451 1/2 inch 18V LXT Lithium-ion Driver Drill Kit. This innocent looking driver drill delivers an astonishing 560 in-lbs of torque which is like a beast inside a very tiny machine considering that the Makita is only 9-7/8” in length and weights only 4.9lbs. It has a three speed driver system which is very effective and with Makita’s shift lock system you can quickly change between the settings from hammer drill to driver mode, how cool is that! =)
Makita’s Ergonomic shape fits like a glove with even pressure and easy control, allowing its user to easily complete the job without putting muscle in it! 3-Speed design produces 25% faster working speed with more efficiency in a wider range of applications. LXT Lithium-Ion provides longer run time, 5x lower self-discharge (for use any time) and 16 firm holding contact terminals (for constant high power). Also the Makita BDF451 comes with Two built-in L.E.D. lights for more illuminated work.
45-minute Optimum Charger has a built-in fan to cool the battery to produce more lifetime work. Two-piece armature and field along with externally accessible brushes for serviceability and longer motor life. Makita BDF451 comes with a 3-Year warranty as well.
Click here to get more info on Makita BDF451 18V LXT Driver Drill Kit.
