1 - 6 of 6 Posts
Discussion Starter #1
Hello. I have a Makita 3612C (3 1/4 horsepower, variable speed) that I need some guidance with. Earlier today I was doing some easy routing when all of a sudden the router speed changed, I saw some orange sparks inside the router, and the circuit breaker for the outlet I was using popped. The tool was smoking and emitting the typical burnt electrical smell. After I reset the circuit breaker, I did not run the tool again, fearing I might damage it more. My question is: is the router salvageable? I took it all apart and everything looks ok; the brushes are hardly used and nothing looks burnt or melted. I've read a few posts that say the speed controls on these routers are sometimes the cause of this type of problem. I can replace the speed control for $85. Is there any way to check that the field assembly or the armature assembly is good before I buy a new speed control? In case it isn't obvious, electrical troubleshooting is not my strong suit. I don't want to sink money into this thing if there are multiple parts that are going to need replacing. Thanks in advance for your help.
Sounds like it burnt slap up! My suggestion is to check the Makita website for the closest service center and give them a call. Some manufacturers have a guaranteed repair price for any given tool, they'll either fix it or replace it with a reconditioned tool for that price. Dunno about Makita.
Sorry to hear, my old 3612 from the '80's is still running with only a few sets of brushes and one bearing change.
HTH,
Bill
Welcome to the forum, Brian. Sorry you had to join with bad news....
I love my 3612C for hand held work....
I agree with Bill and would take it to a service centre for a check up. How old is the router?
Premium Member
Retired since June 2000
Good advice above Brian, ask for a quote. It sounds more like the speed control. I've had my 3612C for over 11 years and it's done an enormous amount of work without a problem, it's a great router.
Discussion Starter #5
James- The router is probably 6 years old or so. I bought it new and it doesn't have a whole lot of use on it. No time whatsoever in a table.
Discussion Starter #6
I was messing around with the router today. Bad news, I think. Before I removed the speed control, I turned the router on briefly and ran it at low speed. The router turned on and ran, but definitely not the way it's supposed to - too much sparking, and it felt like it was under load even though it wasn't. I only ran it for a few seconds, as I didn't want to heat it up. I then removed the speed control and wired it to run as a single speed router. It went up to full speed for a few seconds and then the circuit breaker for the outlet I was plugged into popped. There was a good deal of sparking in the motor (more than there should be) while it was running. The circuit breaker popped after only a few seconds, so the router didn't get hot and there was no smoking. I'm guessing this means that the problems go beyond a possible faulty speed control. Anybody care to weigh in?
1 - 6 of 6 Posts
