61 - 70 of 70 Posts
Newb with first router (used plunge router) looking to get a bit set to get started. I noticed that a lot of the small-ish budget sets do not include a rabbeting bit, but the MLCS set does - specifically, I was looking at the MLCS 8377 15-pc set with 1/2" shanks (too newb to have link posting permissions, but if you search for that item, it will come up, or search on Amazon for "B000FJRN8S").
Couple of questions on this set. Does it have different size bearings (and can I move them from bit to bit) so that I can cut different size rabbets?
Are the straight cut bits the correct size to cut dados for US dimensioned plywood, or are they true to size, meaning plywood will fit loosely?
You may want to look at this set,or a similar one for doing a lot of rabbiting:
https://www.amazon.com/CMT-835-501-11-Variable-Cutting-Rabbeting/dp/B000P4JNNG/ref=sr_1_fkmr1_1?keywords=MCLS+Rabbiting+bit+set&qid=1564246102&s=hi&sr=1-1-fkmr1
If you think you'll be doing very many rabbets Jay then you'll at least want to get a set like Herb linked to and if you plan on really doing a lot then you'll want to get a bit with replaceable carbide cutters like this Amana: https://www.toolstoday.com/insert-superabbet-jr-router-bits.html It's a lot more money but you only replace the cutting edges not the whole bit and some say those cutters last longer because they didn't get welded on.
As for dadoes to fit US finish plywood, that's a problem because finish plywood starts out at the correct size but then gets sanded so it winds up undersize. 3/4" finish ply might only be 23/32 or less when sanded. As a result, some members use an exact width dado jig and use a smaller bit and then cuts each edge of the channel separately. Some links to exact width dado jigs can be found in some posts in this thread.
https://www.routerforums.com/jigs-fixtures/137621-exact-width-dado-jig.html
If you think you'll be doing very many rabbets Jay then you'll at least want to get a set like Herb linked to and if you plan on really doing a lot then you'll want to get a bit with replaceable carbide cutters like this Amana: It's a lot more money but you only replace the cutting edges not the whole bit and some say those cutters last longer because they didn't get welded on.
I don't expect I'll be doing much rabbeting or much routing in general - more of an occasional use thing, at least that's what I'm thinking at this point, after having just picked up my first router. I was looking at that MLCS set because I was thinking I could get a budget set that covers my near-term anticipated uses - i.e., round over, dado, rabbet. And when I looked at the sub-20 piece budget sets, most of them didn't have a rabbeting bit, which is why the MLCS caught my eye. The rabbeting bit would be useful if I can swap bearings and cut different width rabbets.
Thanks. OK, so I'll scratch the idea of getting plywood/undersized bits.
That makes the MLCS set even more interesting because it could cover everything I have in mind near-term: round over bits, straight cut bits (used with an exact width dado jig for plywood joints) and rabbeting bit.
If someone makes a budget set with just those bits, I'd be interested - no plans for making anything for indoors (furniture, picture frames, etc.), so no need for a lot of the bits. The MLCS was the closest thing I could find.
For just occasional use the MCLS bits are OK, I have some, but for serious work I use the Infinity or Freud. And there are other good sets out there, but you get what you pay for in router bits.
There are usually sales going on during the year that some good bargains can be had.
The best bet is to buy just the bit you need to do the job on hand and then you have it and can buy a different one for the next one, that way you build a set of bits that are used for the type of work you do.
Straight bits are not that expensive and can do a lot of standard cuts., by using the fence on the table to set the distances. and with bearings to do template routing ,which you will like once you do it. it just requires a straight bit with a bearing guide on top that follows the template you make and cuts out the part exactly like the template.
https://www.infinitytools.com/routing/router-bits/carbide/general-purpose-router-bit-sets
My Sommerfeld bits are door sets, except for the dovetail bits that came with their dovetail jig. The quality of goods made in China depends on the marketing company's inspections and standards. For example, Laguna has its hybrid table saw and 14/12 band saw made in China (Taiwan is also China), and Laguna demands they seson their cast iron for 6 months or more so it stabilizes before milling. That kind of thing makes all the difference. I almost always buy bits as I need them. I have a strong preference for Freud bits, which are available in 2 days online, or 20 minutes at HD.
That's what I'm anticipating. And if I find myself making more than anticipated use out of a particular bit, I can step up to a Freud or other high quality bit for that profile.
So any straight bit can be adapted with a bearing to do template routing, or you have to get a straight bit + bearing as one assembly?
Jay, any straight bit can be fitted with a bearing and retaining collar ( outer diameter smaller than the bearing, and with a grub screw). However there is a practical limitation: for template routing the cutter diameter must generally be larger than the shaft of the bit, as the outer diameter of the bearing must be the same as the diameter of the cutter. If you look at one of the bit catalogues (I use the Lee Valley one, mostly to salivate), you will see the available combinations. If the shaft and cutter, are the same diameter, e.g. a straight 1/2” or 1/4” bit, you would need to sandwich the bearing between two retaining collars, which kind of defeats the purpose, except for some very clever applications.
There are of course exceptions, but these are usually not for straight bits, e.g. for dovetail bits, where the bearing OD may be larger than the cutter OD, depending on the fingers of the template.
Have the MCLS chinese-made starter set but been replacing the ones I used most with Whiteside. Not sure if it's only me but it's night and day as the MCLS leaves a significant mount of tearout when doing dados for drawer bottoms. The Whiteside bit leaves very little to none.
it's not you...
Reactions: Ray Newman
A few years back there some really cheaply made bits from Asia that were made essentially the same as your local hardware store copies a key for you. They were really crappy. Poor carbide, sometimes not brazed well, and roughly sharpened. The gap has narrowed some because I don't think there is any maker left who isn't using a CNC to make them now, but the carbide quality, the sharpening, cutter geometry, the brazing, and quality control can still be issues so you still get what you pay for.
There are some rare circumstances when the rules seem to change a bit. I was talking to an uncle a few days ago who I consider to be a master woodworker. He was using a Freud to try and profile some knotty western red cedar. WRC has notoriously hard knots and the Freud chipped right away . Freud is supposed to use a C4 grade carbide. He switched to a cheaper C3 grade carbide bit and finished a fair size run with no problem. C3 handles impacts better than C4 does but isn't as hard so wears quicker.
61 - 70 of 70 Posts
