I have not seen that issue.
I usually joint one side on the jointer and later, use a thickness planer to reach required size...
Not all wood is created equal. As part of the selection process, you want to look for grain direction and if there are any sudden changes in direction, an indicator of stresses present in the wood.Wow- I’ve never heard of or seen that happening. Did you ever figure out the issue or a workaround?
