Impressive looking sign, Joe.
Thanks!Impressive looking sign, Joe.
Hi David, I've still got a lot to learn.Very nice work, indeed! I've cut aluminum one time and had the wrong bit so it didn't work out very well. How does bronze cut compared to aluminum?
David
Wow... too bad you couldnt flood coat it in paint... then bring to a stroke sanderHi David, I've still got a lot to learn.
I broke 3 or 4 endmills on my first attempt at aluminum. It's really counterintuitive to see bits snapping at 20ipm and people saying "You're going way to slow!!" But they were right! I went up to 100ipm and no more broken bits. (Kinda like swinging an Axe vs trying to push it through the tree.)
Also, The heat is displaced with the chips so at 20ipm I was boiling the WD-40 and charring the spoil board and weakening the bit. At 100ipm no heat at all.
Aluminum vs Bronze = Pine vs Maple.
I don't use any lubricant on Bronze and it doesn't even get warm.
I was trying to think of a way to incorporate metal into a wood project, like an inlay but I think it would just end up looking like stick-on letters???
Yep, painting it then sanding the letter tops and bevel this afternoon, then "JB weld" it to the granite.Wow... too bad you couldnt flood coat it in paint... then bring to a stroke sander
to finish off the letter tops.
Go for it!! I just got a cheap box of 1/8" 2 flute endmills (those 10 for $10 on Amazon) and started cutting. I'll be getting an Uglysign mister someday, but for now it's just a can of WD-40 and my air hose. 👍Joe, Very nice work on the bronze plaque! Thanks for providing the info on milling. I have a similar project I've wanted to tackle for 3 pet memorials and have been hesitant to try it.
I have 3 pieces of 18" X 18" X 1.5" soapstone I'd like to try with a vbit.Go for it!! I just got a cheap box of 1/8" 2 flute endmills (those 10 for $10 on Amazon) and started cutting. I'll be getting an Uglysign mister someday, but for now it's just a can of WD-40 and my air hose. 👍
I'm thinking about sinking a 90deg vbit into a piece of black granite without water and just see how that goes. We'll see!! 🙂
Hi Woodie, if you're lucky you can recycle a piece of damaged plaque from a monument company. 🙂 but when you run out of that, you'll have to check https://www.metalsupermarkets.com/ or others.Where did you get the Bronze?
... you'll have to check https://www.metalsupermarkets.com/ or others.
