I have about 200 mature pines (18"-36"+), and not nearly as many hardwoods. I won't be harvesting many hardwoods, only a selective few. I do have a source for hardwoods if my needs go beyond what I have but I doubt it.
I'm no pro like you Chuck but I'm quite comfortable falling and bucking a tree. I have a medium sized saw, Husqvarna 455 with 20" bar and will use it to set up my mill and get comfortable with the process on smaller pines before I step up to a heavier more powerful saw. I plan on picking up a Husqvarna 395xp if I feel like milling is worth my time.
I plan on using the pine lumber for non ground contact building around the property, cladding for a goat barn, chicken coop, and whatever else we'll need. So rough cut pine will due just fine. I would like to use the hardwoods and any any heart pine if there is any for woodworking projects but like you've stated planing would be an issue but not impossible. Money saved on the goat barn and the like is money spent on new tools
This is me long term planning. We have some usable pasture but in the future, the pines have to go. So I have time to fell and mill as needed. I have no intentions of milling all 200+ trees but I want to use what I can sense I have it. I've contacted a couple logging companies and they are not interested in buying the trees. They want trees that are slick 16' up and under a certain diameter. One company was interested for pulp wood but they won't give me anything for them. It's too small of a job for them to make money. There is a guy a couple miles up the road with a portable mill but he wants way to much. I might as well go to the lumber yard for material that had already been planed.
My current issue is that I have about a dozen trees I need removed. I've already cleared about 6 others. Some were standing dead and rotten but the others I cut the trunk to the lower branches (about 10' in length) and drug them on top of a couple phone poles to keep them off the ground. The tops and branches have been piled to burn.
I would like to make use of these trees and not burn the lot of them. But will the lumber I harvest from them be full of cracks because they weren't milled soon after being felled? And if so, how bad would it be, just the ends or the full length? The commercial sawmills around here use a sprinkler system to keep the logs wet while in waiting to be milled to prevent this from happening.
I know this forum is woodworking and not forestry services but I figured someone might be able to answer my questions, you guys really know your wood.
Sent from my SM-N910V using Tapatalk
