Hi All,
I have my Milwaukee 5615 router mounted to a table using a homemade polycarbonate table insert. I'd like to upgrade the plate to an aluminum version to fix some sagging issues. However, I'm having trouble determining which aluminum plates will work with this router with regards to the bolt hole pattern. It appears most of the aluminum plates on the market don't specify the hole patter dimensions. Instead they're advertised for fitting mostly Porter & Cable routers but I don't know which P&C model # matches the Milwaukee model on the hole pattern. I've taken my circular router base plate to the local Woodcraft store but the only aluminum plates there have about 20 holes in them to match every pattern available! I'd like to avoid that!
So anyway - if anyone has other routers (P&C in particular) that have a 3 hole pattern where the holes are ~2 3/8" from the center then please let me know.
Thanks!!
Greg
Thanks!!
Greg
