1 - 5 of 5 Posts
Hi. I have a porter cable compound miter saw, is not used for chopping 2×4 on a job site. I have shop in my garage where I dd small projects . My problem is that the saw will not cut a true 90,. When I cut a wider board (7” to 8”}it leaves a notiiceable hump iin the middle {put it on the table saw and it rocks}. The fence is square to the blade. I replaced oem blade withe a Freud thin kerf blade. still have the problem.
Any body have any suggestions.
Thanks Joel
Sounds like you are getting runout on the blade. This is either caused by bad bearings, or a bent arbor. If the saw is still under warranty, I would get it replaced.
If not, I don't know how serviceable the saw, but if the arbor is bent, I would consider retiring that saw and replacing it with a newer saw.
Joel are you using a cheap square to check 90 with? Not all squares are that accurate. One way to check is to take a sheet of something with a really straight edge like mdf or particle board and make a 90 on it, then flip the square over and see if it follows the line. The detents on some saws are also not very accurate, at least not from the factory.
Mike nailed it. If its not under warranty it should be easy to break the case and remove the bearings. Go to a bearing supply shop with them and buy two new ones. If its not the bearings its probably the arbor
1 - 5 of 5 Posts
