1 - 6 of 6 Posts
Oliver (Prof. Henry)
Discussion Starter #1
About two years ago I made a pair of bench top saw horses out of some scrap plywood and they work well when I need to raise my work off the bench. However, they often require clamping in place to keep them from sliding around and then I have to clamp my work to the top of the horses.
Recently I saw where Woodsmith made some bench hooks out of 2 x 4s and the way they worked looked interesting so I used that concept to modify my bench top horses.
The modification is simply adding a removable hook to one end of the horse and a hole for a bench dog in the top of the opposite end. I made my hooks out of 1 x 2 poplar with two holes drilled in the face: one for a 1/4” bolt and one for a 1/4” dowel. The bolt attaches the hook to the horse and the dowel keeps it vertical and prevents it from turning. I’ll probably add a knob to the bolts for convenience. The end of the horse riser has a threaded insert for the bolt and a shallow hole for the alignment dowel. I’m able to leave the hooks attached when I store the bench top horses so I won’t misplace them.
Maybe you can adapt the concept to suit your bench top needs.
Very nice idea Oliver. It's nice to have someone like you to help the less fortunate out. ""Like me""
Ross
Good one Oliver.
Simply brilliant or is it brilliantly simple. Leonardo would be proud!
1 - 6 of 6 Posts
