1 - 16 of 16 Posts
Several years ago I purchased Incra's Express sled for cross cuts on the TS. The sled works fine for cross cuts on relative small workpieces.
Recently I needed to cut some large workpieces, namely the floor and lid for a cedar chest. The standard Express Sled was way to small for such large cuts. The lid for example is 23 x 42 inches.
I looked at the Incra 5000 with its own miter gauge and fence, but it was to expensive in light of my already having the ES with incra's V27 and an add on Incra Fence.
I phoned Mark Mueller and found that I could buy the panels for the 5000 and install them on the aluminum plate for the ES.
I put the panels on sled this morning and it's a really sweet set up now.
I can do cross cuts up to 30" with the arrangement and the width of the panels is such that the extention for the fence is completely supported for the 42" wide cut, it's all that I had hoped for. Very safe and easy to handle. When I ordered the parts from Mark, he made the remark that the modifications would make the sled very heavy, but in my opinion it is not so. Needless to say, I'm very happy with it.
Jerry
Good decision, Jerry, I would like to see some pictures of that set up, not quite sure how you added it to what you already had.
Discussion Starter #3
I can get some pictures, but they won't be what I'd like. The reason is that I did not get a panel that fits between the aluminum plate and the blade. I have e-mailed Mark about it and am sure that I will get one. In the meantime I had to use a panel from the original sled and the finish has been removed from its' surface.
The reason for the finish being removed is that a couple of years ago a tornado took part of the roof off of the shop and everything got drenched including the panels on the sled and the MDF swelled up. I had to plane them just a tad so that they would still work, so if you will over look that for the time being, I'll go get some photos for you.
Jerry
Premium Member
Good for you Jerry..... but dang, I NEVER would have thought you would get 30"s out of those panels. That is pretty impressive and
well worth my considering. Once again, you dogged attitude comes through :)
btw: not to shabby a glue up you got going there !!!!!
Discussion Starter #7
Bill,
You noticed the glue up, yeah I'm catching on, splines were used BTW.
Did you spot the pretty little Hagner SS in the background of one of the photos.
The saw is the one that Herb sent to me, it's a dandy too by the way, Thanks again Herb.
Jerry
Dang,Now thats a Texas Sized Table saw if I ever saw one! That sled looks great, I see why Incra gives you personalized attention, you are their best customer.LOL
By the looks of the size of your shop , you need the riding mower to get from one machine to the next.
I am happy you got the little Hagner working and that you like it. You are giving it a good home.
You did a nice job on that panel, be sure to post pictures of the chest when you are done.
That sled has the same dimensions as the "shop," (spare bedroom) that I work out of!!! Absolutely awesome!!!
Discussion Starter #11
I think that buying the system the way that I did, starting with the Express sled and
modifying it by adding the 5000 panels cost more than I had spent. I person starting with the 5000 will cost less money. You would get a better miter gauge and a better fence set up too.
Discussion Starter #12
Obviously I did not edit my most recent post about the cost of modifying an Express Sled.
What I wanted to say is that if a person were to buy the 5000 to start with it will cost less that what I finally spent by buying the Express Sled first and than adding the 5000 panels to it. The 5000 also has a higher end miter gauge than what I ended up with which is the V27.
Guess that you get the drift of what I was trying to say in the original post, but I felt that I needed to say it
better.
Jerry
Premium Member
I wonder if my 2000 would work in the 5000 package? Then I could take the 3000 and use it as a stand alone???
Discussion Starter #14
Bill,
I thought that it was yourself that sent me a link to the specs on all of Incra's miter gauges, if not, somebody did and we can find it again, I'll have a look.
Jerry
Premium Member
Jerry..
looks like it just might work.. according to Incremental, the 5000 works with all of their miters except the v27...
Discussion Starter #16
Bill,
Jerry
Here is the link to what I was talking about, I don't see a 2000 listed but the miter bars on the higher end gauges all look to be the sme which leads me to believe that what you are asking about would work,
I don't understand Incra says that 25" is the capacity of the sled as it appears to me in the real world to be considerably more that that as I mentioned in an earlier post.
Jerry
INCRA Miter Gauges :: Miter Gauge Comparison Chart
1 - 16 of 16 Posts
