Did you spalt the boards yourself or buy them that way?
The rough sawn boards are about 1 1/16". I plane them both sides and resaw them down the middle and run them through the drum sander. finish thickness is 3/8-7/16" thick. There is some soft spots and insect tunnels and holes I have to cut out or work around. Some I dig the sawdust(from the bugs) out and fill. I haven't found any live critters living in them.Did you spalt the boards yourself or buy them that way?
That is good to know, Chuck.I found out by accident that you can spalt the wood yourself. The spalting as you probably know is rot. By spalting the wood yourself you can stop the decay process before the wood gets too soft to work with which would allow for the mitered corners. I found out when I covered some green birch boards with planer shavings and then found out 2 months later that I had a leak in the roof where I piled the boards and the shavings had gotten quite wet and stayed damp pretty much the whole time before I decided to check on them.
