Loblove
I'm glad that you are happy with your new DC, at least you are not disappointed from something that you paid for.
About 6" and 4" piping...
I will assume that you don't know so much of Aerodynamics (and you do, I apologize)
When the air flows over a surface (in this case it's your pipes), the nearest layer to the surface has zero velocity.
The second layer has some higher velocity, the third, higher and so on until the air gains the "free stream velocity" (in this case, the "free air velocity" is at the center of your pipe).
This layer, that the air velocity changes from zero to the free stream velocity, is called "Boundary layer", it's turbulent and causes "loss of momentum" or in simple words; it slows down the air flow in the pipes.
Just for the example, lets assume that the thickness of the Boundary layer is 1/4" (that is very close to reality) and it will be 1/4" over any surface (or if you like - in a 1" pipe and in 6" pipe the Boundary layer has the same thickness).
Now just imagine that you are using 1/2" diameter pipe...1/4" around the pipe is the boundary layer with reduced velocity and you shall have only the center 1/4" diameter with "free stream airflow" (or the highest velocity).
Now, increase the pipe diameter to 1", the Boundary layer is still 1/4" but the free stream diameter is now 3/4" and the more you increase the pipe diameter, the more free stream area you get.
When the surface (or the pipe) is long, the Boundary layer becomes more turbulent and thicker, so keep the piping as short as you can. I'm using a shop-vac (R2D2) for the TS and it's removing almost all the dust, I use a 2" hose but only 3' long.
Another factor that you have to consider is the "elbows" or T-connection, try to use minimum "turns" and if you have to (normally), use moderate elbow, say 30° turn or less.
What happens when the flow is forced to turn at 90°, it does not want to turn but wants to continue at the same direction and "cavities" are created, the airflow over a turn is very turbulent and creates a lot of drag or "Momentum loss" and in total reduces the airflow velocity.
Of course, if you have unlimited HP to overcome all those "Momentum losses" (or Duct losses), no problem but, you have only "advertised" 1.5HP so better to keep the losses to minimum.
Wow, that was long but, I hope that it will help you to organize your pipes.
Harry
Next time I'll wait a little bit more time and save me the typing (with two fingers...)
Regards
niki
