An update on this project. I got sidelined with an earlier project that needed to be finished.....literally finished. Seems I have this issue when it comes to sanding and putting a finish on a project. I always said the perfect wife likes to sand and apply finish.....mine is just super great ......but not perfect so it's up to me. So now I'm sanding and applying finish to the 3-in-1 stand and working on the sliding table in between coats which actually are going pretty fast.
The top coat finish says under ideal conditions you can wait 2-4 hours between coats and mine is dry within 45 minutes to an hour. The shop is at 45% RH and 69.8 degrees which seems to play very well with this finish so not as bad as I had thought. But it also means I'm jumping back and forth which the sciatica really doesn't care for after a few hours on this concrete floor. 30 years later and it's still a pain in my thigh.....
Anyway here are some pictures showing the bones of this sliding table. What I need to do it take the stationary rods out and drill through the centers so the #8 x 3" screw can go through the rod to hold in place. The stationary rods are the ones on the outside moving pieces. The base box in the center the rods and Acme screw pass through. In the Centering Close Up photo you can see there is a large hole and smaller hole where the bushing and Acme nuts passes through the wall. The larger hole is where the epoxy putty need to be applied to hold those centered and in place. I've never used epoxy putty so this should be fun.
I need to do a bit of sanding, clean the threads on the Acme rods but I don't think I'll put a finish on this. I don't really see a need as it will be a stationary setup. I've lifted that mortiser several times already and due to its shape it's too heavy to lift often as there aren't any real good places to grip it. And I'm getting old.....I still need to build the cabinet for it and it too will be on wheels. Now to see how to align these rods and use the epoxy.....
Almost forgot, not sure that wood end on the clamp is a good idea yet but at minimum I'll need to taper the wood contact side to meet it squarely and if that doesn't prove effective I'll get the rubber tip the plans call for. I wasn't able to find one that fit that M12 bolt pattern.
Back to the finish, I did put a coat on the fence and will add (3-5) several more as it will be in contact with the wood being worked on. What isn't shown in the pictures is the iron angle that is used as the old down. That's at my buddy's being cut and then I'll need to prime and paint that. Got a nice Hunter Green to contrast with the Powermatic yellow. OK it was on sale........
