Mountain shelf
3036 Views 17 Replies 16 Participants Last post by  Bstrom
4
My oldest daughter wanted a shelf to hold her essential oils. She told her younger sister about one she saw on etsy. My youngest and I tackled the project together so she could give it to her sister for her birthday. We made it from rough cedar fence boards that I planed down to 3/8". The ones we saw online used 3/4" and looked a bit rough hewn. The thinner boards made clamping a challenge. Using pin nails, blue tape and an assortment of clamps eventually brought it all together. I was having a lot of trouble with the top peak when I remembered a trick I read about where you shoot pin nails into a the end of the board under low pressure then cut them off and use them like dowels to hold the position during glue up.The miter sled did a great job on the 30 degree angles. Finished it with shellac and wax.
1 - 18 of 18 Posts
Nice job Jamie , that is really neat
I see what you mean about creative clamping, good job, never seen one quite like that.
HErb
Reactions: 2
Nice work Jamie. I will have to make one for my daughter.Thank you for showing how. James.
Jamie,
Nice job. I really like it.
Frank
I would think she's ecstatic about the outcome. Not your usual shelf and you made it your....rather hers. Very lucky young lady.
Nice outcome, interesting design.
Really nice project and good solutions in the build process.
Nicely done....!
Any chance we could get some dimensions on this excellent piece? That appears to be the hard part(?)...
Great solutions on the clamping; well done!
Great design, fit and finish!
That turned out fantastic! You did a great job with all the angles and joints. The finish looks good too, Cedar fence boards are not the easiest to get smooth and straight like that. :cool:
Dimensions: 17 3/4" wide by 13 3/4" tall by 2 1/2" deep. Cedar 3/8" thick boards. Bottom shelfs are 3 1/8" tall to allow the 2 1/2" tall oil bottles to fit with a bit of space. The angles are 60 degrees. The left peak is 9 1/2" tall, centre peak 13 3/4" and the right peak 10" tall. If I did it again I would make the side peak height more varied to show the height difference.
Make a full size drawing first. Really helps with sizing the boards before cutting the angles. I set the angle on the table saw then cut all the boards on a cross cut sled.
Many thanks - this will make a great gift to a few folks.
1 - 18 of 18 Posts
