Ok, I am back after a few weeks with yet another plea for help from my friends at Router Forum. You see, I have been busy these past few weeks and one of my projects is making a cross cut sled for my table saw. However, being Mr. Ridiculous and Mr. Perfection at the same time I have a dilemma. As you can see from the attached photo my sled is just under an 1/8th of an inch away from the blade. On the other side I will attach another short width of plywood that I can adjust for using a dado blade. This other piece will snug right up to the blade on the right side. Question, should I be concerned with the small gap on the left side? If so, how would you recommend that I fix it so that I am not chasing my tail? Do I put in an end mill of the appropriate size and use my router table to widen the miter slot on the left side. Or, would you recommend that I leave the miter slot as is and glue a piece of 1/2 inch baltic birch plywood to my existing piece and then just trim it to width with the table saw. Can I even glue the plywood with any chance of it staying attached for the long term?
Thanks as always for your advice.
Jim in Phoenix
Jim in Phoenix
