1 - 8 of 8 Posts
· Registered
Hello all, I am new here.
All, I am trying to find out if the MRP23EVS, which I am considering purchasing, has a compatible mounting system to the 1617 such that tables that are designed to accept the 1617 would also accommodate the MRP23EVS as well. Any help appreciated.
-JM
· Official Greeter
Welcome to the forum, John Mark.
· Registered
When I bought my MRP23EVS last spring, it came with both bases but the fixed base is setup for upside down mounting for a router table. I was in Rockler’s store on Woodward Ave in Detroit so I had them open it up and we tried on their router plate I was buying at the same time. At the time they only had a older series Bosch plate in stock which did not allow for the height adjustment wrench through the bottom but all the plate mounting holes lined up fine so I bought it and simply drilled an additional hole for the height adjustment wrench. It’s all been working great.
· Registered
Discussion Starter · #7 ·
The 1617 fixed base (1160) has the same screw hole pattern as the 23 but a different screw size! So the holes in the 23 plates are smaller.
4M's on the 23, 10-24's on the 1100. Plunger is a different story.
So, I guess that plates drilled for the 1617 will not work with the 23. :sad:
Amazing how little support there is for the 23 out of the box.
-JM
1 - 8 of 8 Posts
