I know someone looked for this a couple of years ago. I recently got one from an old friend. It's in very good shape but a bit rusty. The pulley nearest the blade lift wheel side seems very loose on the shaft, and has the brass insert only on one side - about half the pulley. This does not look right to me. The other potential problem is that it has only one belt which will only run in the inside groove on the motor pulley and outside groove on the saw shaft pulley. It looks like if was designed for 2 belts. I presume this is just a motor alignment problem, but would be delighted if anyone out there has a copy of a manual or any advice
