I went back and read my original post and I did bad mouth the MC but I was wrong. It is a quality piece of work. When I bought the MC they called and ask if I was going to use it in a router table and I said yes. They said I needed the extended version and I said okay. Of coarse it didn't work and they swapped it out at no cost to me. I thought I had everything solved but when I but a bit in there with a cutting length of 1" and the I couldn't make my cut I was mad and disappointed. The reason and only reason I bought the MC was because I was having trouble changing bits in the router table. My offset wrench was slipping off a lot and I was afraid I was going to break the carbide on one of my bits. I got a new router table with a lift and I hope I will be able to use the MC with it.
You were frustrated I have been there, we all have believe me. I hope the new router table works well for you.
Do you have one of those bent wrench(some call it an offset wrench) for the router collet? I found mine helped me get the bit out much faster and simpler when I did a lot of router table work without some kind of extended reach collet. It allowed me to get at the collet when it was below the table surface. This might help for the times you can't use that muscle chuck. They make the bent wrench for some of the most common routers. I must have at least 3 for different routers.
I never know when stuff is obvious or it may be helpful. For most guys that know about them ignore me, but for the few newbs that aren't aware these bent wrench may be helpful, I used mine quite a bit:
