"Info:# Of Grooves On Head - 3 | Nut Size Across Flats - 1 in."
I think those work on metric too!buy a whole set of SAE wrenches...
26mm and a shim...That nut doesn't require very much torque Bob. I torqued mine too much and caused excess run out doing it. A 26mm would probably work well enough to get it on if an adjustable spanner doesn't work.
But then you gotta buy a metric and a standard onebuy a whole set of SAE wrenches...
Ah yes, the universal inch/metric wrench ...buy a whole set of SAE wrenches...
